Mystery red wire with a fuse in it
Old 12-22-2009 | 05:30 AM
bk/y are normally ground on the OLD BIKES? HAHAHA, lazy right now. yes, BK/Y is still common on the 05
  #52
Old 12-22-2009 | 05:38 AM
Larry ftmfw's Avatar
I traced the wire to under the fuel tank
  #53
Old 12-22-2009 | 05:39 AM
Odimus's Avatar
i did the dual headlight conversion and bumped it up 5 amps with no problems...stock bikes don't have that wire...when I get home in the AM i will take a look and see whats going on under there...
  #54
Old 12-22-2009 | 05:44 AM
It looks like a ground wire that runs from
the bottom of the gas tank but i have no clue why the red wire is connected to it.
  #55
Old 12-22-2009 | 05:47 AM
Odimus's Avatar
another idea is that you should pull the red wire out and use 2 separate wires and hook them to the originals...there may be a problem with the wires being twisted together...
  #56
Old 12-22-2009 | 05:48 AM
Odimus's Avatar
do you know the previous owner???
  #57
Old 12-22-2009 | 05:51 AM
I dont want to screw it up any more than it is.
  #58
Old 12-22-2009 | 05:53 AM
I dont
  #59
Old 12-22-2009 | 05:55 AM
Odimus's Avatar
if you were in the area I could look at it...I'll have more info for you tomorrow night though...
  #60
Old 12-22-2009 | 05:56 AM
Ok so now that we know its a ground wire, would that explain the fuse blowing? If so would it be ok to use a 15 amp?
Quick Reply: Mystery red wire with a fuse in it
