Motorcycle lifts or stand?
Old 09-11-2008 | 05:53 PM
HUNTER1's Avatar
Default Motorcycle lifts or stand?
I have a small cruiser eliminator 125, I would like to work on the rear and front sides, which is better to buy, the lift or independent stands? or are the stands for sport bikes only? thanks.
Old 09-12-2008 | 10:45 AM
williamr's Avatar
A rear stand that can be used with spools or cups under the swing arm (you can switch from one to the other) is ideal for most jobs, including chain adjustment, oil changes and general maintenance. Team it with a front stand if you need to work on the forks or front wheel.
A lift is lovely, but can't be used with a lot of bikes. An Abba stand is also good - better than a rear stand but less convenient to use. Rear stands aren't needed with bikes that have centre stands.
I buy gear like this with the next bike in mind, and the one after that, not just my current bike, so I'd start with a rear stand.
Rob
Old 09-12-2008 | 03:36 PM
HUNTER1's Avatar
Sounds good, thanks.
wt crawford
01-04-2013 04:22 PM
stephenmarklay
03-26-2012 11:30 PM
ErikOrlando
06-28-2007 07:02 PM
keithB
05-24-2007 02:58 AM
Quick Reply: Motorcycle lifts or stand?
