Lubing Throttle Cable
RE: Lubing Throttle Cable
The chromed end screws off to reveal a removable split rubber collar. The handle is wound fully back, fill brass tube with oil, slot open ended cable into split rubber, refit threaded chrome end to seal, wind in the handle and the oil (under pressure) forces its way down between the inner and outer cable and you have a lubed cable. You can use any fluid lubricant. Don't use on split outer cables for obvious reasons!!!
Mike
Mike
