KE 100 lights question
Hi all, I just got a 96 KE 100 , had been sitting for some time , got the carb and tank cleaned out and she's running pretty good. got a stupid question about the lights, the blinkers come on when you turn on the left or right switch, but dont blink and also they don't glow with the headlight , is this right or could there be a fuse bad some where? Any other advice appreciated , been a while since had a two stroke . thanks - Tom
Sounds like a fuse is out or your flasher unit is bad. A friend of mine's wife is actually looking for a bike exactly like that. Tell me how fast can you go on it? She's a small gal, so she was wondering if it will do 55? Thanks man. Oh and welcome to the forums.
![Wink](https://www.kawasakiforums.com/forum/images/smilies/wink.gif)
Check and make sure that the bulbs are of the correct wattage, check your electrical connections (unplug, inspect and tighten), then look at your relay/flasher. (Was checking out my 76 KE manual and it only showed the relay.)
Fun little bike , top speed with me at 200lbs looks like 50. got it for my son , but I'll probably play on it too.
any idea where the flasher/relay might be , inside the headlight maybe? , dont see one under the seat. found two fuses under the seat but they checked fine.
thanks
Tom
thanks
Tom
dcPE
Concours
09-11-2014 04:24 PM
dcPE
09-11-2014 04:20 PM
