I just bought a 636 ninja and have a question
i just bought an 05 636 ninja and I was wondering if anyone knew the answer to this question; I don't know much about bikes so any info would be great:
basically, when i turn the key to the 'on' position the speedometer activates and the lights turn on. At this point I hear a clicking sound under the seat that goes for a few seconds. tat-tat-tat-tat. This is prior to starting the engine.
is this sound normal? If not can anyone tell me whats wrong? thanks for the help
-j
-j
RE: I just bought a 636 ninja and have a question
A relay should not chatter lemac. The fuel pump makes a noise though and sounds like a chatter on start up.
edit: But the pump is not under the seat either.
I know relays dont chatter, they click... The discription he gave made me beleive it was a relay click. Prior to start up. At least thats what mine does. I could be wrong though. Good luck with it and welcome to the forums.
A moving exhaust valve without there being any power/movement in the engine? Now that would be neat.
I get a couple clicks from relays as well on my 9, and the fuel pump primes... and on the 9 it is under the tail end of the tank... the sound could appear to come from under the seat a bit if the 636 is located in the same place. I would say the clicks are normal, as they are activated in a sequence so as not to put max load on the batt and rest of the electrical system... kinda like a car.
On OD's when you kick the key on you hear the gas pump kick in under the gas tank area then you hear hear a couple of clicks under the seat. I should know I get to ride it more than he does now LOL
WELCOME to KF!!!
edited cause I forgot the welcome hehe sorry!
WELCOME to KF!!!
that sound is the exhaust valve servo motor and if you have a aftermarket pipe with the servo stop, the clack clack clack seems louder. go ride !
SupaMoto
06-20-2013 04:40 PM
