I have a question?
Old 12-17-2006 | 07:42 PM
KawasakiKLX125's Avatar
Default I have a question?
I have a 2005 Kawasaki klx 125L, I have only had it for about a year now. I pulled it out of my shed, and I havent ran it in about a month. When I hit on the throttle in neutral it runs fine, but when im in 2nd gear and above, it bogs out. I checked the spark plug, the air filter, changed the gas tofresh gas (gas might have been old). How can I solve my proplem without it bogging when I ride.
Old 12-17-2006 | 09:52 PM
firstninjabike's Avatar
Default RE: I have a question?
did you change the fuel filter?
Old 12-18-2006 | 01:32 AM
it doesnt have a fuel filter, only an oil filter
Old 12-18-2006 | 02:40 AM
it has to have a fuel filter, a damn lawn mower has a fuel filter
Old 12-18-2006 | 06:19 AM
sillyhillbilly's Avatar
ORIGINAL: firstninjabike
usually the only fuel filter is the screen in the fuel petcock
other than that most smaller/simpler bikes dont have one at all unless it has been added
Old 12-18-2006 | 06:30 AM
shinobi636's Avatar
Did you check the vacuum lines (if it has any)? a cracked, or removed vacuum line could cause that. The engine not advancing through the rpms under load would cause that also.
Old 12-18-2006 | 08:58 AM
Good ideas to throw around. All petcocks have a screen, I still placed an in line filter. Yup cracked rubbers is another thing to consider with your ride.
Old 12-18-2006 | 04:58 PM
ORIGINAL: Dragone#19
No body wants a broken rubber
Old 12-19-2006 | 09:23 AM
Drain the float bowl into a cup and see what you find?
Old 12-20-2006 | 07:00 AM
shinobi636's Avatar
Good idea. You might want to see if the fuel line is clogged also, without a filter all kinds of crap can end-up deposited in there.
Quick Reply: I have a question?
