How To??
RE: How To??
Allows you to play with your power band some. Plays with the cylinder fill rate, combustion and exhaust rate. I do not have any numbers for an 04, cam degree. You only need to play with numbers ie cam numbers if you have a full system, take that back, I used the stock exhaust after the cam degreeing, stock size head gasket, with the overbore with no timing alterations. Got my cam degrees thru Muzzy. Check it out and make a call. If the top end is modded, why not do everything at the same time? As far as gains go? Never dyno'd my '90.
RE: How To??
Well the bike has a vance and hines slip on, but I need to get a new mid pipe and I cannot locate one for it so I am thinking about going with the Micron or D&D, I havent been able to find a Muzzy system for the 94, so they may not make itanymore. I dont know if u read my other post or not Drag but I did find out what the problem was with my highbeams, it was the relay the whole time, but nowIm thinkin that the turn signal relay is bad cause its not flashing but if I tap therelay it flashes, you tell me what you think.
