How To??
Old 09-02-2007 | 03:37 AM
sfgpgt's Avatar
Default How To??
How do I remove the motor and tranny from my 1994 ZX7 I am getting ready to put a 765 kit in it and need to know, thanks Dale
Old 09-02-2007 | 03:50 AM
Default RE: How To??
Your manual covers that topic pretty well, at least my H2 manual did.
Old 09-02-2007 | 07:53 AM
sfgpgt's Avatar
Well it looks like I am going to have to spring for a manual LOL was tryin to keep from doing that right now, but I guess it would be a good ref to have around, which manual do you recomend, my local kawi dealer has the clymer manual is it a good one? Thanks for all your help dragone by the way, you have given me some helpful advice. Dale
Old 09-02-2007 | 05:34 PM
Didn't mean to sound like an a@@, but if you are digging into something this much the Factory Service Manual is the way to go. Trying to explain engine removal online would be a tough one and I would feel bad if I may have forgotten something, or if you did not understand what I was trying to say.
Old 09-02-2007 | 08:09 PM
niklucas's Avatar
His right, you know. Lol, I've got my manual from Dragone BTW, he's a good sport. I put it to good use already, chain slack needed someadjustment.
Old 09-03-2007 | 03:32 AM
jeffzx9's Avatar
Dragone's right; get the manual.
However, the abbreviated version is: Get bike on front stand/rear stand. Remove plastic, Remove gas tank. Disconnect darn near everything, including throttle linkage, chain and exhaust. Drain the engine oil. (If memory serves me..) Roll your floor jack with a board with a drain hole cut-out --just to accomodate the bolt head) under the engine, to take the pressure off when you disconnect the bolts.You may want to have a friend handy when you unbolt the motor from the frame. Unbolt front frame downtubes. Carefully unbolt the rear of the motor near the swingarm pivot area.Engine should be free. Roll very carefully out from under the frame. Your friend and youpick up the motor and put it onto the bench.
Like Dragone said though, if you're getting in this deep, follow the manual. I'm just sitting here recalling how I did my 9 motor. They should be very similar.
Old 09-03-2007 | 04:00 AM
Dang, about the only thing different that I did was by raising the front/supporting the ride with straps from the rafters. hahaha Right on Jeff
Floor jacks, jack stands, plywood for the jack, straps are great to have. Of course keeping all of the bolts organized and marking hoses and cablesare always a plus.
Old 09-03-2007 | 04:13 AM
evil636's Avatar
Knee Dragging Pimp
take the pipe off too
Old 09-03-2007 | 08:24 AM
sfgpgt's Avatar
Yeah I agree with all of you guys on that, Im gonna go pick up a manual this week some time
Old 09-03-2007 | 04:11 PM
BlackNinjaZX6R's Avatar
good call good luck
