Hotbodies undertail brake light help!
Old 08-02-2009 | 03:18 PM
Paid Dues's Avatar
Default Hotbodies undertail brake light help!
Need help! I just bought a 2006 zx-6r a month ago and now the brake light is not working so i'm going to try and change it... does anyone know the best/easiest way to do this with the hotbodies undertail on it?
Old 08-03-2009 | 03:53 AM
jeffzx9's Avatar
Looking at the instructions on the Hotbodies website is no help. Most undertails result in hand-contortion to access the taillight bulbs. I'm no expert on the '06 6, but I would suggest getting some soft jaw pliers to reach through the space under your (removed) passenger seat. You may want to inspect the wiring, as the undertail installation process can pinch wires and cause shorts; may not be your bulb(s) at all. However, if it IS the bulbs, I'd replace with LED's (like an 1157 bulb only LED).
Good luck!
Tdizzle
04-18-2009 07:29 PM
SKOOTR
12-22-2007 02:17 AM
intense_05_636
07-25-2007 05:01 AM
silverzzr600
07-22-2007 01:00 PM
aveisone
05-08-2007 08:13 PM
