Help. 2002 kx 250
Help. 2002 kx 250
Hi all
I have a kx250 with a pooly engine. The other day i had just started the bike letting it warm up when it fired a load of engine oil out of the exhaust and stopped runing. i have got the piston and rings out but they don't seem to have any damage to them is there any thing else that could have made this problem. hope you can help all thanks jon.
Why would you pull the top end before a compression check?
What exhaust are you running and what other changes are with the motor?
What mix and with what are you using?
What plug are you running and is it, well...... it will be fouled now.
Just curious.
Welcome to KF
norsseman
KLR650
11-08-2006 07:11 PM
bls5782
06-13-2005 06:25 PM
