head lights not working
i have a 2000 zx6r and my head lights dont come on i checked the fuses and the wiring seems to be okay and when i tested it with a volt meter only one wire had power on it, any ideas on what the problem is or how to fix it?
RE: head lights not working
You can check relays, but you will need to be able to understand the wiring schematic that is usually on the side of the relay. You need a 12v source and ground to power the relay, and a Ohm meter to see if the relay is working when power is applied.
Trust me though, you're better off just replacing it.
