gpz fuel problem
Old 08-20-2008 | 05:17 PM
fraser123's Avatar
Default gpz fuel problem
hi people 1st bike prob ran out of fuel whilst doing a bit of work in my garage on refueling petrol is running out a pipe which appears to be going into air filter box on inspection box is full of fuel i assume its a float jam problem is there an easy fix cheers
Old 08-20-2008 | 11:04 PM
RonInFla's Avatar
First, try tapping on the float bowls. If that works, get the carbs cleaned.
If that doesn't work, get the carbs cleaned,
Also, put an inline filter on. The crud clogging the carb came from the tank.
Old 08-21-2008 | 03:52 AM
hahaha, and 3rd, just get the carbs cleaned as you clean the tank and lines. Yes, good idea on the inline filter placement.
Old 08-21-2008 | 04:42 PM
fraser123's Avatar
just lovein the sympathy lol thats what i get for buying a 2nd hand tank although am sure i flushed it right out hay ho ok in line filter av got 1 lying around and a carb clean dont u just love it when u make an *** of yourself
Old 08-22-2008 | 12:05 AM
hahaha, It is all good fraser, I should have frequent flyer points as well on some of my reasoning.
abstractmoment
04-09-2011 01:57 AM
86gpz1000
04-21-2010 04:52 PM
turace24
05-12-2008 04:10 PM
turpehar
Classic Sportbikes
05-24-2007 04:24 AM
utterly kwakkers
06-14-2006 05:28 AM
Quick Reply: gpz fuel problem
