Gel Battery Versus Liquid Acid
Has anyone ever experienced or used the newer Gel filled batteries yet? Any Pro's or Con's to these compared to a regular battery? I'm thinking of trying one in my ZX9r.
Thanks!
Thanks!
RE: Gel Battery Versus Liquid Acid
Never used one, but they are about the same as optima batteries you put in cars. Gel cell batteries are not much different than a liquid lead acid battery. The liquid electrolyte found in a regular battery has just been gelled up by silica. I think the internal lead plates inside the battery are also more closely spaced together. These batteries are much more vibration resistant than their liquid electrolyte brothers which means a longer life.
Vibration is one of the biggest reasons batteries go bad in the first place, followed by excessive heat.
Great, I'm going to get one!
Taking a closer look into these I also notice that the discharge rate on this type is longer, meaning it can sit longer without a charge. Might be beneficial over winter storage? Plus they come charged already.
Thanks,
Thanks,
That's great! If you remember years down the line, tell us how long it lasted. BTW: Do you bring your batteries inside for winter? It's important that you do. Batteries discharge very quickly when they're cold.
I messed up. I bought the Glass Mat instead. Oh well, hopefully this will do me alright.
The battery was dated 2001' on a 2000' bike, but you're right about removing from the cold. I don't have a battery tender either, but started the bike every (2) weeks ofver the winter, I know I should have brought it in out of the cold garage - but I didn't. Will have to to get the life out of this one.
Thanks!
Thanks!
