Gas in my oil?
Old 05-08-2008, 10:48 PM
markmeinteil's Avatar
Default RE: Gas in my oil?
It is probably getting sucked in through the crankcase ventilation tube. The gas is back flowing into the air box where the crankcase tube islocated.
Old 05-09-2008, 01:31 AM
x2fast2belegalx's Avatar
the crank case tube is below the carb connection a good 4-5 inches. also took that tube off and ran it for 10 mins or so and nothing came dripping out. so dont think it wuld be that. appreciate all the help guys.
Old 05-09-2008, 02:50 AM
BigRig18Wheeler's Avatar
I'm not real sure....But, lol, if it was mine. I'd pull the carbs and do a manual inspection of the floats, needles, seats, etc.... I bet when you dumped her, it has summin a little outta wack in the carbs, which would PROBABLY be easliy identifiable upon manual visual inspection.
Old 05-10-2008, 10:25 AM
ORIGINAL: BigRig18Wheeler
yup, cable adjustment, floats, seats and synch can be out of wack.
Old 05-11-2008, 08:15 PM
will dothat then. ill post word wen i take it apart and find out.
Old 05-12-2008, 04:02 AM
Prom's Avatar
ORIGINAL: x2fast2belegalx
didnt ride it and overnite it showed the oil above the top.took some out agin 2day but did not replace it entirely. yet thatoil has no scent of gas.
Since it didn't smell like oil after it filled up, check your other fluids as well. if you had serious internal damage you could get coolant in the oil as well. I'm willing to bet its the carbs, but doesnt hurt to check.
Finger Mullet
10-21-2008 02:03 AM
gerrynolan
09-07-2008 01:25 PM
MaverickAus
05-19-2007 07:45 PM
cassa63
08-17-2006 09:37 AM
kawi636
04-04-2006 09:26 PM
Quick Reply: Gas in my oil?
