Fuel Types????
Fuel Types????
Just curious if most bikes take regular unleaded or premium? I have an 01 zr7-s that has no owners manual, and there is no stickers to indicate fuel type. I know if you run 91 octane in a car that is designed to run on regular then it will cause carbon buildup on the pistons and valves b/c it burns slower. Is it the same with a bike? The bike is completely stock.
Run premium for a tank or two, then check your plugs. What color deposit under normal riding conditions? Also, check your exhaust; if you have a bunch of carbon build-up around the tailpipe (which you should also see evidence of on the plugs) then try some regular. Personally? I run regular fuel with some Chevron Techron mixed, about every other tank.
Liv4accelor8ion
05-10-2007 03:26 AM
