Fuel Pump question for a 97 ZX-11
RE: Fuel Pump question for a 97 ZX-11
Forgot to add one more thing, I went and got the battery tested at an auto parts shop and they said the battery was good.
Is it possible that the battery isn't good and isn't holding a charge?
I figure who knows who had the bike before me, and how long it sit, this is all considering that the battery or the throttle response went down minutes after I started her up.
I know how it feels to be getting closer to the fix along with all of the troubleshooting that can be involved.
It sounds like you're on the track now and you should get it soon.
ORIGINAL: clay8up
The voltage is a good sign.
Alright guys thanks for all your help,
I finally got the bike started, got a good spark and fuel running through it now, but now another dilema. [sm=violin.gif] WA WA[sm=headbang.gif] Do the problems ever end....lol Well at least I have a good aditude about things.
Here's the problem now, The bike starts and idles great. Also when it is in nuetral it rev's like the beast she is, but don't try to put it in gear and drive off cuz thats when the motor flutters out. I just can't figure this one out, how can the bike idle and rev to 10,000 RPM perfectly in nuetral standing still but not rev over 3,000 RPM in gear without stalling, any ideas? I'm lost.[:@]
Ok check this out, mine has the kickstand safty switch
http://www.ronayers.com/fiche/400_03...0&parent=13990 (part number) 27010A
but when my kickstand is down it doesn't kill the motor, like I said before in my previous post when the bike is just sitting, kickstand down the motor runs perfectly. But when I first purchased the bike the kickstand switch worked, it killled the motor when I put it down. Hmm, maybe this bike is using some kinda trickery.......lol
I'm doin to try putting the other stand up and the kickstand up and see how it reacts.
The safety switch will only shut the engine off when you try to drive away with the kickstand down. Only at take-off does it shut the engine off, you can idle with the kicksatnd down. Then as soon as you try to drive away, it will cut the engine immediately. Not sure if this is your problem, but just a check.
I'm not sure if your's is the same as my ZX9R. I would suggest getting a service manual or go to the public library and see if there is one there that would help you out.
The procedure for my bike is as follows;
(Bike is off)
1) Remove the seats
2) Shift it into first gear and set the side stand to "On" position. (I think this means sidestand down)
3) Set the hand tester to the 25 V DC range, and connect the positive tester to junction box Black lead. And the Negative tester to the frame ground.
4) turn ignition to "on" and push the "starter button"
5) Read the voltage. Voltage should be 6 ~ 13.4 volts
Don't know if this helps or not.
(Bike is off)
1) Remove the seats
