fuel pump
RE: fuel pump
most carburatos that i've run into other than garden tools still need a fuel pump and want anywhere from 3-8psi (atleast from my autoomotive experience)
my 95 zx6r is carbed and has a fuel pump.
RE: fuel pump
ORIGINAL: Dragone#19
Even my '90 zx7 has a fuel pump mmi86.
Put a gauge on it and test the pressure smokey.
when pumps start to go bad they will still flow gas if disconnected btu when connected can't maintain pressure at higher flow rates required (start starving the motor at higher rpm)
RE: fuel pump
ok im on k-dealer.com as we speak, looking at all the 93 models no fuel pump in the tank, ie, where else would kawi hid the little fellow, olny thing isa fuel separator which is not the same thing as a fuel pump it stillwork off of vaccum
