front wooble
Old 01-28-2007 | 01:06 AM
PANGUI's Avatar
Default front wooble
i get a crazy wooble in the front tire when i get up around 110 - 120 area any suggestions on how to get rid of it anyone???????
Old 01-28-2007 | 01:24 AM
gotrice's Avatar
Default RE: front wooble
Hyper-pro.LOL I would check to make sure your front tire is in good condition. Also make sure your front forks are adjusted the same.
What type of bike?
gotrice's Avatar
Causes of the shakes are:
- road surface (extreme road camber or potholes or corrugations)
- loose handlebars or clipons (serious!)
- rider posture (sitting too far back)
- loose or worn front axle bearings or axle
- loose or worn headstem bearings
- incorrectly aligned front wheel
- loose forks or fork clamps
- loose brake caliper (generally only on one side)
- misaligned fairing (which touches or restricts one fork)
- incorrect front suspension setting (generally much too hard or soft)
- too much power being applied (reduce throttle usage...hahahaha)
- flat front tyre (or incorrect air pressure)
- flat rear tyre (or incorrect air pressure)
- tyre/wheel imbalance (unusual)
- incorrect front tyre wear (sides scalloped or worn profile
Old 01-28-2007 | 01:36 AM
+1 GR, incorrect balancing or loosing the rim wt and the loose steering stem bearings are prolly the most common issues.
Old 01-28-2007 | 02:04 AM
PANGUI's Avatar
03 636 power commander K&N filter hindle exhuast front tire a little chafed up it only woobles in between 110 and 120 does anyone have any maps for this bike
Old 01-28-2007 | 02:32 AM
joel7676's Avatar
All the above things are good answers... l feel your pain... l was going throught the same thing with my bike...getting a steering dampner is big thing but that only takes care part the problem the other is loosening your rear is definetly going to help.....also dont forget the road has alot to play with it too....... one last thing you can also do the opposite tighten the rear and take some pre load off the front so it makes the front softer ...the down side to this is the Zx6 always come with hard suspension....so I would not recommend this option....but for everyone to reach their own... good luck....
Old 01-28-2007 | 02:47 AM
PANGUI's Avatar
thanks yeah i know the road has alot to do with it but it has happened to me a few times
Old 01-28-2007 | 03:43 AM
wow, only 10mph difference for the wobble. A chafed front tire to you looks like what to us? Cheapest and easiest check is static balancing that front wheel again. Then while placing the front wheel after balancing, check some of the other possibilities listed above concerning the front end.
Old 01-28-2007 | 05:59 AM
PANGUI's Avatar
i think a chafed tire looks the same to everyone i will do the static balance and see if it help thanks everyone for your help
Sid Post
04-22-2008 04:26 PM
SIRLOIN
09-01-2007 12:12 AM
Quick Reply: front wooble
