Front wheel spacer ZX6R
RE: Front wheel spacer ZX6R
Make one. Go to a junk yard and buy some stock. If one of your friends has a drill press, after you cut the proper width, locate the center, use the proper bit and viola. Probably less than 10 bucks.
Ta for that but that's kind of the point.I don't know any one with a drill press. And cutting to the right width is measured in fractions of millimetres and would need to be machined to the right width.
Measure the width of the speedo drive, the axle OD and post it. I'll see if one of the spacers I have will fit/ match those dimensions. What year & model bike are we talking about?
