fi light
code 62= Subthrottle Valve Actuator see page 3-98 of your manual for testing.
If the actuator resistance is within spec (5-7 ohms), check the input voltage. Could be a loose/worn connection on the plug.
Good luck on the find
edit: welcome to KF
edit: welcome to KF
Hit up a pdf manual posted in the General Discussions area, listed under manuals. See page 3-98 for testing. (fairly sure that there was an 04 manual in there anyways.)
ok tested ohms on servo and sensor both good.checked input voltage on and cotinuity on allthree wires all test came out good . i dont know book says ecu i dont know. bike runs fine when i turn key on what are top butterflies supposed to do any help would be great oh checked output voltage to good as well
let us know.
Jammin'John
2000 & 2000 Limited
11-14-2012 12:14 AM
Jammin'John
11-12-2012 11:42 PM
dubbg69
Ninja 250R
10-22-2006 05:23 AM
