fender eliminator for 98?
RE: fender eliminator for 98?
IMO the zx6r doesn't need the fender kit.
just chop off the fender .. remove the reflector take the plate bracket move it up were the reflector was, drill two holes to secure it, flip the bracket upside down, then mount...
I think this looks better than the fender kit.. cause the fender kit make you cut a lot of the under tray out...
i was looking around the web site, and with just a quick look i couldnt find any kits for a 98, mostly just 05's, im gonna check that out again onewheel, i had looked at that before it does seem easy to just cut, i was also thinking of trying to find the fender down at the tire, because right now all the crap from the road shoots right from the tire onto my shock and i dont really like that too much, is there a way to rig up like a small fender on the front of the rear swingarm like some bikes have?
if you look really close you cane see that I did make up a small fender to cover the rear shock before I got the tire hugger
I took a piece of 1/8' plastic cut it the way I likes and fit it up to the battery box
but like I said the fender kit is more work than the way I did it
