EX500 Overheating
Old 11-12-2007 | 09:20 PM
mxrayser's Avatar
Default EX500 Overheating
I've got a 87 ex500 thats running hot! I've drained, flushed and refilled radiator. The thermostat seems ok, although it runs a little cooler with it removed. I'm not sure if the fan comes on, on it's own, I do know that when its hot if I turn off ignition and turn on again the fan will start. Any help is appreciated!
ThanX,
MX
Old 11-12-2007 | 10:29 PM
jeffzx9's Avatar
Default RE: EX500 Overheating
When the engine gets hot, does it puke coolant out the radiator overflow tank? If it's an '87, I'm guessing it's a head gasket. The thermostat won't help this problem, and you're better off to leave it in place. Check your oil for any coolant contamination (you should see globules in the sight window.) However, if you don't see contaminant, it doesn'tnecessarilymean your head gasket is OK: I've had bad head gaskets without coolant getting into the oil.
Old 11-12-2007 | 10:40 PM
mxrayser's Avatar
Yes it pukes coolant out the overflow, just changed oil and it's fine. Any way of checking head gasket?
Old 11-12-2007 | 11:10 PM
jeffzx9's Avatar
You can do a compression check, but without the proper tools, it can be a pita. I'd seriously bet on the head gasket. (What is technically happening, is that there is leakage between the cylinder(s) and the coolant ports in the head, causing pressure buildup. The coolant gets hot, expands, and the air gets into the coolant path and eventually out the overflow tube, because it has nowhere else to go.) The overflow tube (from the overflow tank to the ground)looks like a latte frother when it blows the hot coolant onto the pavement, (right?) Not to mention the coolant temperature gauge just keeps climbing......
It's not a bad job to replace the gasket, just make sure you label everything and get all of the old gasket and gunk off the head surface. Use Scotchbrite pads and Acetone. (Wear gloves.)
Old 11-12-2007 | 11:57 PM
mxrayser's Avatar
I'll do a comp. check, and let you know what I get, ThanX
Old 11-13-2007 | 06:23 AM
dilysi's Avatar
hold on what coller are the electrodes of the spark plugs it could just be running lean start easy then move to advanst
Old 11-14-2007 | 04:29 AM
mxrayser's Avatar
Cant find my comp. tester, i'll buy anoth]er one tomorrow but I'm leaning towards the head gasket. Plugs are tan, but their old and 1 heat range higher than stock, so I'm gonna replace them with stock heat range. So where besides ebay can I get a head gasket for a decent price?
Old 11-14-2007 | 04:38 AM
Old 11-14-2007 | 04:42 AM
dilysi's Avatar
where they wetdid they have droplets of water on them is the bike modded at allintake or exhaust?
Old 11-15-2007 | 04:45 AM
speedracer138's Avatar
start the bike with the radiator cap off. If it starts shooting water/ coolant out of the radiator, it's a blown head gasket. If it doesn't. it could be a stuck thermostat or a bad water pump. It could be as simple as air trapped somewhere. Is there a bleed screw somewhere near the top of the engine. Check behind the cylinders or head. A bad radiator cap that is not sealing can cause overheating. Make sure the seat for the cap & center plunger is clean & sealing.
DragonZ
12-19-2006 10:11 AM
DragonZ
Ninja ZX-1100R
11-26-2006 10:50 AM
silverado
09-25-2006 06:59 AM
tbav8or
07-29-2006 05:53 PM
Gerg
06-26-2005 04:41 AM
