Do I need a new sproket yet?
RE: Do I need a new sproket yet?
It looks fine.Is it tearing up your chain?If not than your good to go.By the way if you change the sprocket you need to change the chain also.Once a sprocket has been running for a while it and the chain develope a wear pattern.If you run an old chain with a new sprocket it will chew the sprocket up and vice versa with a new chain and old sprocket.
