Couple of maintainance questions about EX250s
I'm new to motorcycles. I've worked on cars for a good while now though, I know all the theories of internal combustion and what not. What I was wondering is what kind of oil, coolant, and other fluids a '99 EX250 Ninja requires. Also if you could give me an idea about the system capacities and what not I'd much appreciate it.
RE: Couple of maintainance questions about EX250s
Did you get the owners manual for the bike too? If not I would say either to go to a Kawasaki Dealer or look on eBay for the manual. I know you should be able to find them cheap on eBay.
Try this link out, it might help. I came across it a while ago on a local forum that I'm on a lot. If I come across anything else that I think you'd be interested in, I'll pass it on! http://home.swiftdsl.com.au/~tenoq/GPX250Manual.pdf
RE: Couple of maintenance questions about EX250s
coolant is coolant in a bike I don't know of any bike using anything special like dexcool GM coolant.
but oil is different... you have a wet clutch witch means that the trans oil and the engine oil is the same and run together.. there should be a sticker some were on the bike stating what types of oils that is compatible with your bike.. if not call your local dealer and see what is recommended
