Clutch Box
Old 09-20-2006 | 07:30 PM
yaba3800's Avatar
Default Clutch Box
Hello. I have an 05 636 ninja and i noticed that near every fluid on it is dangerously low. on the right side of the bike there is a twist off cap on the side of what i assume is the transmission. when i open it i can see what i think is the clutch.. but there is absolutely no fluid in there that i can see. is this normal? if not what fluid do i put in? thanks!
Old 09-20-2006 | 08:00 PM
markmeinteil's Avatar
Default RE: Clutch Box
That's your oil fill cap. Unless you over filled your engine, you won't see any fluid at the top of it. There is a round sight glass below that shows how much oil the engine has. You must check the oil level with the engine off, and the bike either on it's center stand, or by holding it up yourself.
Old 09-21-2006 | 04:43 AM
yaba3800's Avatar
i got it! thanks.
RayCour
07-21-2010 10:35 PM
deej
10-02-2008 09:58 PM
stoney
01-01-2007 05:58 AM
JERSEY
04-23-2006 08:30 AM
Quick Reply: Clutch Box
