Carb Jetting
Welcome to KF
Do a plug chop after you have made sure that the float height is correct and that the carbs are synched.
I do a trial and error method.....go up 2 sizes and run a plug chop. so if you are running 105 mains then hit up the 110's. I do not have a set number for your application, but if you are going to be running the pods with the exhaust....I probably would try the 110's first.
Let us know on what you find out. Enjoy
