Cam 2
RE: Cam 2
I believe you are refering to 100 octane cam2.It is a good high end fuel.It will burn more thoroughly and give you a small gain in power.It is not uncommon to mix this with 93 50/50 so as o not be too expensive.There isn't really a disadvantage with cam2.However if you run Sunoco Super Blue or VP fuels they can harm your fuel system after a while.
RE: Cam 2
JMO but there is no real reason to run any high octane fuel or racing fuel in street bikes, even if you’re going to the track. Most bikes are tuned to run using normal fuel and will not benefits for the added octane like a racing bike which has been built to run on the higher octane fuel.
But like I said JMO. Search “100 octane cam 2” yahoo
SDRRider
07-06-2006 09:00 PM
