Bike not starting? (tick tick)
RE: Bike not starting? (tick tick)
Thanks for all the replies folks, really glad to see them.
As for push starting it, I did try that, and it was a no go.....The bike would semi start up for just a second and it would die almost as soon as it started....So that's a no go
I'm going to go out this weekend and check on all of my connections and what not. I'll let you know how it turns out...
Thanks alot!
Thanks alot!
ORIGINAL: Trelaboon
Thanks alot!
Thanks alot!
Yes, there's fuel in the bike, I rode it home after it was repaired at the shop, I went out to start it a couple days later and this is what was going on....I don't see how a battery dies in 2 days though? and when I charge it, it says "Battery Charged" so it must be some sort of wiring connection like you've said or something?
Trel, you are saying that you do not have a volt meter to check this? After fully charged, the battery is prolly like 12.7-14 volts. If the key is in the off position, keep your leads on the battery. Does it drop in volts?
edit: sorry, use a volt meter. I maybe did not specify too clearly.
