Battery OVERCHARGE - bike dead
I was working in the garage and hooked up my battery to charge it up a little bit because it had been
sitting in the garage all winter. I got distracted and left the garage and left the charger on. Approximately
24 hours later I returned and realized what I had done.
The battery still seems to hold a charge after one week.. but when I go to push the start button it does
nothing. The red FI light flashes and then stays on.
What did I destroy when I left that charger on? It's a 2004 ZX-12R.
I realized I should have purchased a battery tender... don't remind me : )
Thanks in advance. - Jase
RE: Battery OVERCHARGE - bike dead
Wait.......no hey guys this is my first post, glad to have found this site, you guys are awesome, I have been lurking for a few weeks now........nothing? LOL Just messing with you, Welcome anyway. Using a standard battery charger on a motorcycle battery is not the best idea, (idear if your Paul Sr.) If you do use a regular battery charger it helps to put it on the 1 or 2 amp slow charge if equipped with that. Other wise it tends to boil the battery. Also using a higher amp battery charger on a battery without unhooking the cables can have a negative (no pun intended) effect on other electrical components. If it were me, I would start out with a new, freshly charged battery and see what happens. Oh and buy a battery maintainer and wire in a pigtail hidden on the bike so all you have to do once a week is plug it in. Both of my bikes are set up that way to charge through the 12V accessory plug I installed on them. I can also us the outlets for cell phone charging, GPS (if I ever get one) and best of all I made up a small set of cables with a male 12V end so I can jump start either bike in case someone leaves their lights on out in the woods.
Thanks for the reply. My thing is... I think I fried something electronic. The battery is holding a charge just fine.
I actually did set my bike up with two remote wires from the battery so I could hook it up easily or hook
someone else up. My battery charger also has the lower amp option for motorcycles and a low maintenance
battery tender option.... unfortunately when I left it on it was on the regular charge... I don't know how that
battery is keeping a charge at all now.
I think I may have fried a circuit or fuse or heaven forbid something bigger like the fuel pump.
Thanks for the "welcome" deej.... : )
Find a friend with a bike, borrow their battery... see if it cranks. If not... let us know
It's kinda hard to "over-charge" a battery
Of course - check all your fuses first.
