AIR/FUEL SCREW SETTINGS
Does anyone know what the correct settings are for a 97 ZX7, stage one dynajet kit, float bowl mod, slip on pipe. I have tried 3 turns, 2 3/4 turns and it seems to run good for a while and then goes back to the low speed stumble. Does backing them out richen or lean it?
2.5 turns is the correct setting with ur mods. you do know you have a idle adjustment **** on the left side behind the fairing right? b/c on my bike ifs its cold outside and the bike is cold, the adjust **** has to be set different than if its hot outside or if the bikes warmed up.
