99 kx 250 carb..
99 kx 250 carb..
my 99 kx 250 seems to have a solenoid and sensor .. what are these for and how do they work .. were they ever a problem ?? and can i ride with out them hooked up ? my kx didnt have one of them hooked up when i first got it and it was still super powerful and i was able to pull the front end in fifth gear ??
per 1999 Kawasaki KX models
The restyled and revised 1999 KX250 has even more power than before. Engine performance is further improved with the addition of a new carburetor featuring the Kawasaki Throttle Responsive Ignition Control (K-TRIC) throttle position sensor.
Keihin Power Jet PWK38S Carburetor with K-TRIC
- New "shorty" design places the mainjet closer to the cylinder for improved throttle response
- Kawasaki Throttle Responsive Ignition Control (K-TRIC) uses a sensor and alter ignition timing according to throttle position and engine speed for better throttle response and more power
- Power jet system uses an electronic solenoid to close a fuel passageway at high rpm to extend the power peak and increase top-end power at over-rev
DirtSurfer
03-25-2018 07:26 AM
