87zx600r wiring nightmare
i own a zx600r motor, i got it on a old shadow frame... lol
i got the wiring diagram and wired in the coil packs in2 the ic box.
i got 2 wires left over black/yellow and black/white.
i plug the box striaght in2 the connector out the throttle side of the block then i got 3 yellow wires out the alternater, when i turn it over no power on any wires. alter?? but its turning over dead like. may need more rpm!!
ic box colors 2 block wires stock connectors plug right in
yellow/black 2 black
yellow 2 yellow
blue 2 blue
red/white 2 black/white
i dont think the box is suppose 2 plug in2 that connector so i might need 2 wire it in diffrent??
when i ground the black/y and black/w it gives me grounds in 2 of the block wires but still no fire. i think one of these wires gives all my wires power that i need??
i have nothing else, no regulater or juction box.
when i turn it over nothing has power but whats wire in and thats the starter.. relay wire coming out is white.. possibly it could connect 2 the 2 left overs i have out the ic box i dont wanna burn nothing up...
yellow 2 yellow
blue 2 blue
Welcome To Kawasaki Forums.
Turn On Same Tunes And Enjoy The Ride.
Theirs a lot of Good Members Here and they will do there Best to Help You out with Your Questions. Sometime It Takes A Little Longer Then Others. So, hang-in there. Have Some Fun.
Pic's do help at times
i got the black/ yellow grounded. and the black/white 2 power and now i have power on every wire 2 the coil packs... 12 volts is that correct? once i find out witch wire is ground and power every thing else seems 2 b right! thanx
jhoffy22
06-20-2011 03:06 PM
