86 zx1000 float leaking
hey i think i found my carb problem. the #1 carb float has a hole in it and is about 1/3 full of gas i got the gas out and now i need to seal it any ideas? a new float at bike bandit is 30 bucks. i think this is causing all my problems. any help is appreciated
RE: 86 zx1000 float leaking
There is some plastic epoxy you can get at your local auto parts store that should fix your problem. One of the products I know of is called plastic weld. Just make sure it can handle fuel.
I once had the same exact problem and used the same exact solution. It worked for a while, but not for long.
If your float was old/brittle enough to crack or break the first time, it will do it again. It's just a matter of time. The cheap allways comes out expensive in the end. Just bite the bullet and spend the $30, it's woth the peace of mind.
