82 750 CSR twin fron brake drag
Hello all.... I have a classic 750 and cannot seem to get the front brake from draging. I have cleaned the caliper, blead the system, and even cussed it !!!
It starts out ok and then the handle gets tight and the caliper wont back off. The only way to ease it is to crack the bleeder screw and let off the pressure, and then we start all over again......
toysinbaroda@yahoo.com
Just a thought
The master cylinder has a small relief port, a Primary cup, that if swollen or damaged will cause the pads to drag on the disc. So maybe inspecting and/or rebuilding the MC will eliminate your issue.
redfieldrocket
06-24-2008 05:12 PM
