750R Starter Drive???
Hi, this is my 1st post in the forums, i am very new to the street bike world. I just bought an 87 750r for a really great deal. The guy said it needs a new starter drive. It takes a long time to get the bike started because it seems the teeth are ground down and arent really grabbing to turn the engine over. Ive looked up "starter drive" on a 750r and found nothing. If anyone knows wut i need to replace or how difficult this will be i would greatly appreciate some input. I plan on getting hardcore into riding and would love to get this bike going asap. Once running the bike sounds amazing. I have to ride it!! pls help!! Thanks in advance
RE: 750R Starter Drive???
welcome to the forums!! I'm guessing the starter teeth are ground down. I think what they're refering to as the drive is the gear that pops out when you hit the start button. i don't know if you can change just the gear or if you have to change the entire starter. If it was me, I would change the entire starter assy....... If the gear is bad, the starter's probably not far behind it!! Gl man....
I think your right, ive been trying to look that up and it seems you can only change em out on PWC but no motorcylcles. Hopefully i can find a place that sells em cheap, and that the job isnt tooooo hard. Thanks for the help.
So i pulled the starter and wow, no teeth at all, which made me happy Now i know the problem for sure. The thing im worried about is the "flywheel" (not sure if thats wut its called but bear with me). It has about 8 or nine teeth missing from one section which only makes up a small portion of the circumference. Will having 90% of the teeth be okay? Im sure that is a hard to find part and even harder to change. I figure if i hit "the patch" of missing teeth i can roll the bike a few inches and find fresh meat. Correct me if im wrong but that will work right?
ORIGINAL: 750R87
Do not mess with an unbalanced piece of equipment (teeth). More things will happen and the prob will only get worse and be more expensive.
