750R Ninja in Storage
RE: 750R Ninja in Storage
Yup, as mentioned above. Your carb boots are prolly cracked now also and check/replace vacuum lines, check your cush drive on the rear to make sure that they are not all shrunk. Get new tires while you are at it. I would soak the chain in diesel fuel for a couple days also. A long storage sucks.
Yup plan on new tires(they look great though)battery change oil, coolet, bleed brakes-clutch-clean out gas tank, but what about the engine-is there something I should do before turning over for the 1st time-if need parts who are the companies you guy recomnd for older bikes
