520 chain conversion 04 zx-6r 636
Well im changing my chain and sprockets. It was sugested I change to a 520. So i picked up a RK gold 520 chain and a rear sprocket thats 520 conversion with 42 teeth. I got a new front sprocket also that is -1. My question is when you convert to 520 I know you need a diffrent rear sprocket then would use for a 525 chain but do you also need a diffrent front sprocket to run the 520 or would the same front sprocket for 525 work for 520?
RE: 520 chain conversion 04 zx-6r 636
I agree with walight. The size has to be the same.
edit: otherwise you will damage the brand new sprocket and also the chain. You may even jump the chain and damage the ride let alone you while running that combo.
Object
05-12-2008 02:15 PM
Object
04-12-2007 07:54 AM
