250 ZZR Back Shock bottom out
RE: 250 ZZR Back Shock bottom out
The ZZR is the Canadian/rest of the world 250 model. They are much nicer than ours in the states.
If your Ninja is like the 250R sold in the U.S, the rear shock is non-adjustable. You should be able to upgrade to the adjustable 500R shock though.
Sounds like to me you don't have your suspension set properly. You need to get the sag set for the rider weight, both shocks and forks. Go here to help you get them set right. http://www.sportrider.com/tech/146_0006_susp/
Get a couple of buddy's to help you out. Should only take you about an hour to get it set right. Then some minor tweaking on the rebound and compression and you will be good to go.
Mike Fournier
03-02-2015 05:36 AM
