2016 Ninja 650 running problems need help
2016 Ninja 650 runs but not well I've changed spark plugs coils I've given it a compression test which has good compression by the way it runs in idles fine but when you give it gas it like runs runs good for a second and then it just goes into like a like a bog mode it just bogs out and thenjustruns as if running on one cylinder after that oh when writing it for a while the muffler or the catalytic
converter whatever you want to call it I'm overheats you can actually see it it's orange and red and very hot so if I could get some help on this particular problem or if you need more information I will gladly get that to you thank you for all your help
