2012 brute force 300 leaking fuel from carb
Old 09-05-2022 | 02:09 PM
JTM's Avatar
JTM
Default 2012 brute force 300 leaking fuel from carb
Good morning, I'm looking for some suggestions.
I have a 2012 brute force 300. It has been about 2 years since it has been ridden. When I took it out riding recently it is leaking fuel out of the carburetor drain tube. This happens when the machine is off with the fuel valve on, as well as, when it running at idle and at low speed under light throttle. It doesn't appear to leak at higher speeds under moderate to heavier throttle positions. What might cause this problem ?
Any insight would be great!
Thanks
Piesg
10-07-2019 03:38 AM
sooner66
04-18-2019 11:59 AM
usmcdad
06-11-2016 09:27 PM
austino65
08-01-2012 02:23 PM
IB Adrian
04-14-2011 05:58 PM
Quick Reply: 2012 brute force 300 leaking fuel from carb
