2007 Mule 3010 Over Oiled......
Hi. Asked my son to check the oil n the mule, he said it was a little low and that he added some. Great. Went to drive it and blew enough white smoke that it looked like I was fogging for mosquitos. When I checked, he added about 2 quarts on top of what was in it. So I had oil coming out of the air filter and oil in the carb. Pulled the air filter and hoses apart, drained the oil and cleaned them. Took the cover off the carb, drained it and sprayed it with carb cleaner until it drained clear. So now I start it and it runs solid for about 10 seconds and then cuts out, almost like its not getting air. I can't find anymore air hoses or vacuum lines. Please, ANY help or suggestions is appreciated. Got a hunt coming up and need the mule!
Thanks
Bill
Thanks
Bill
Well mine is a 610. It's blowing blue smoke and only holds 1.5 quarts in total. I think we have different problems. I really don't know what causes white smoke other than maybe some carburetor adjustment.
Good luck my friend.
MikeT
MikeT
