2000 zr-7 crankcase help
Old 04-14-2008, 03:32 AM
jay42782's Avatar
Default 2000 zr-7 crankcase help
Size:  15.8 KBName:  010.jpg
Size:  14.2 KBanybody know how to access cad-cam files and specs for a engine case??? i am in need of some tech. info
i bought this bike that was stuck in nuetral...pulled the side cover off to find out some nuckle head tryed to fix his own case and didnt do so well
it is the part that the shifter mechanism slides through..............it has been broke and the new peice they put back on was not alingned correctly.so i have to some how figure out correctlenth,width,inside/outside diameter of original peice? any suggestions?? thanks guys!!
Old 04-14-2008, 04:36 AM
whitehendrix's Avatar
Default RE: 2000 zr-7 crankcase help
hmm.. lemme look and gauge out the turbo motor... see if i can get the dimensions for ya..
the actual cad/cam specs are uber hard to find, since thats kawasaki's mealticket.. someone gets those specs, they can upload it into a DNC file converter program and crank out genuine kawi parts ona CNC.. not good for them..
thus the reason why specs are top-secret..lol
BUT. i have a dial caliper and i know how to use it!!
get back to ya in a day or so..
Old 04-14-2008, 11:59 AM
jay42782's Avatar
ORIGINAL: whitehendrix
this is crazy!!!!! my bike has been sittin for over a year,i have been trying to find info on this and whitehendrix hit me up in less than a day of my post...............crazy.if this dudes boss is on here.......give this dude a raise.............lol.thanks whitehendrix!!
Old 04-15-2008, 04:40 AM
got it covered like a fat chick on a toilet seat, homey.
ok..
these are prolly a lil off.. the motor is sitting on the bench... exhaust-ports down..
this is what it SHOULD look like..lol (turn your head to side..)
the pen points the needle bearing assembly. bearing is an NTN HK 1312
i didn't remove my bearing, so the o.d and depth may be a lil off.. but only a few thousands, max..
I.D.= .529"/13.45MM
O.D.= about .7565"/19.22MM
cage width= about.508"/12.90MM .. maybe 13.00 MM (hard to gauge..)
top of bearing housing to flat of hole's base= .7085/18.00MM
bearing housing O.D.= 1.043"/26.50MM
outside end of race to bottom of the center of the hole=.850"/21.60MM
shifter shaft O.D.= .5015"/12.97MM
shaft end to washer= .6535"/16.60MM
shaft O.A.L.= 3.815"/96.96MM
the wear marks on the shaft show the edge of the rollers to sit at about .285"/7.26MM off the far end of the shifter shaft..
shifter shafe assembly in end plate..
shifter shaft.. not much to it..
and yes... my poor calipers have seen better days.. but, they're uber accurate and certified to be so..
Old 04-15-2008, 10:47 AM
jay42782's Avatar
your crazy man.................lol !!! i sure appreciate what you have done here.i will keep you posted on progress!!
Old 04-17-2008, 02:18 AM
I was thinking that the cell phone pics have seen better days wh!
Old 04-17-2008, 02:24 AM
kawi750r's Avatar
hey i have those same calipers!!
Old 04-17-2008, 07:26 AM
lol ted and jeff..
that actually is not a cell phone. thats a real camera.. it just blows goats on the up-close stuff..
jeff man.. are your calipers beat to hell also!? lol
oh, btw ted man.. i'd probably ALWAYS use the cell. its great for up-close crap, but i can't upload the pics to the net, cuz sprint is a big, multimillion dollar rapist pig conglomerate of everything i hate about corporate america.
(yeah.. my bills are kinda high..lol)
Old 04-19-2008, 09:29 PM
OK, so my serious Q is why the nasty looking case? Decay? Porous? or just gunk?
Old 04-20-2008, 08:20 AM
weld, i believe, ted..
its a piece of pipe.
as you can see, its WAY thinner than the casting that should be there..
Quick Reply: 2000 zr-7 crankcase help
