00' zx9
Old 07-19-2007, 02:56 AM
mikejasso1's Avatar
Default RE: 00' zx9
well, i chenged th ignition switch, but i don't know about the clutch and neutral switches, can you tell me wher they located?
Old 07-19-2007, 06:45 AM
Hermolicious84's Avatar
Default RE: 00' zx9
Know any certified 12 volt technicians? I hate this electrical stuff too....[:@]
Old 07-19-2007, 07:07 AM
Default RE: 00' zx9
ORIGINAL: mikejasso1
They are located at the respective locations. Clutch switch on the clutch lever for example.
edit: Best way is to look at the fiche or your manual for the location.
Old 07-19-2007, 12:18 PM
mmi86's Avatar
Default RE: 00' zx9
Neutral switch will be a Lg wire down on the left hand side of the motor, it will just be a single wire with looks like a boot, pull that boot of stick a lead from a mutlimeter, to it and another to ground, in neutral you should have about .4- .8 ohms,now as to check the wire for breaks, put a lead on that "boot" and follow the wire to the Ecu ( brain) you should have .2 -.4 ohms there, DISCONNECT THE ECU , dont dont dont back probe that,as for the Starter lockout switch the wire varied from year to year but mostly on the zx lineup it was a bk and a Bk/w wire you might have to take the left side fairing off just to access the cupler, find the 2 pin connector and disconnect it, take side thats in your left hand ( one running back to the clutch) and test that for ohms .2-.4 ohms, now if you find that does in fact not have ohms one fast way to be sure its the Starter lockout switch is bad, take that cupler you had in your right had, and use a jumper lead, ie, a damn paper clip would do the magic, and if shes starts then that thats.
Old 08-01-2007, 03:21 AM
mikejasso1's Avatar
Default RE: 00' zx9
hi guys thanks for your help, now my bike its runing but i have i a problem when i starter the bike it runs but shaking a little bit and if i dont hold gasit just goes off what do you guys think if i hold it all gas up , bike starts misfires.
JDTOYMAN
Ninja ZX-9R
01-01-2008 02:24 AM
hqcool
01-13-2007 07:24 AM
baseballar
10-22-2005 10:47 PM
TATTOOZIT
06-10-2005 03:52 AM
beauxdn
04-19-2005 05:32 AM
Quick Reply: 00' zx9
