Project GPZ update
Project GPZ update
ZX9 guy here again.. Well i finally have the 85gpz 900 together enuf to ride her on the road so i went for a cruise. Carb issue took care of itself after running it every day and adding some carb cleaner (thank god for Sea foam). Bike did everything it should. My oil leak is now under control coming from the clutch case. NOT GONE but i will continue to work on that. I have yet another leak that has surfaced. The clutch fluid is leaking from the clutch slave cylinder glass circle for fluid level inspection. Anyone have a quick fix for that ? My donor GPZ i have has the same issue with its resivoir and i would replace it with that one but i would end up in the same place. Any thoughts ?
There is a sight glass? I must be on the wrong fiche
Kawasaki Motorcycle Parts 1985 ZX900-A2 Ninja CLUTCH MASTER CYLINDER Diagram
Yeah i looked at the illustration and "sight" glass is on opposite side of fluid housing and is not shown in the picuture. I will attempt some 2 part apoxy. If that dont work im JB Welding the **** out of it lol
