need some help...'accelerating' , litterly
Old 04-05-2006 | 09:37 AM
wanna6r's Avatar
Default need some help...'accelerating' , litterly
ok, my old bike (04 800 marauder) was 64hp...and 485 lbs) you could just go out, amd at any mph crack it WIDE OPEN and just go...i took my 650 out (05 daytona 650) and i barley tapped 1/4th throttle and it popped a wheelie...i then hit 2nd gear and it did the same thing, and im hardly touching th gas...can some one assist me? i wanna go sraight...not up!
any insidte would be helpful....i only have 11 miles logged into a sportbike....i was thinking like ...burn the clutch? let me know please, thanks/// btw im fairly light, lol, 5'9', 130 lbs...
Old 04-05-2006 | 09:58 AM
frrogger1's Avatar
Default RE: need some help...'accelerating' , litterly
you could take it to the dealership and have then check your throttle to make sure it is adjusted right
Old 04-05-2006 | 02:11 PM
txredneckmedic's Avatar
put more of your weight over the tank
Old 04-05-2006 | 05:02 PM
Notstock's Avatar
Sounds like way to much throttle. Go easier on it. If you hammer it it will go like mad. Also the throttle is way different from your other bike, a 1/4 turn to you may be 3/4 or almost full. Check your throttle in neutral and find out how and where it is open and 1/4 open ect.
AJG
10-06-2010 08:12 AM
mrmcfly500r
02-28-2008 03:34 AM
devestator_x
08-07-2005 11:09 PM
ryffryda
08-07-2005 07:45 PM
harryman
06-19-2005 04:11 AM
Quick Reply: need some help...'accelerating' , litterly
