My Heart is Broken……
#31
I would like to see your test results NS. If it is as simple as a top end rebuild. I did mine for around $300 for the cylinders being punched out, oem pistons,rings and clips. Read up on your preferred crosshatching,clearances, and ring material before you get it done. I opened my clearances to .0025" total (kawi was .0015 stock), iron sleeves with a finer hone on the crosshatch. 10 laps and she was ready to go! But I understand you have a coated cylinder, so obviously the price will be different.
2005, bad, blow, compression, costa, cylinder, kx125, kx65, mach, mesa, motorcycle, scarring, scotts, stabilizer, steering
