i want to up the sprocket setup for hyway
Old 02-06-2008 | 04:24 AM
tref357's Avatar
Default i want to up the sprocket setup for hyway
dear kfers where can i get sprocet set for higher dropping of the rpms for hiway,tnx,tref
Old 02-06-2008 | 01:44 PM
Kohburn's Avatar
Default RE: i want to up the sprocket setup for hyway
should be plenty of sprocket sources. just have to check to see what tooth count you have on the front and rear now. then get fewer teeth in the rear and/or more teeth up front.
Old 02-08-2008 | 12:08 AM
onewheel's Avatar
I wouldnt do a front sprocket as that will affect you starting out in first gear. I think that you may go throught a cluth.
I would go maybe -3 maybe -4 in the rear that should give you a lower rpm and better mpg on the highway -3 im sure you would be good with the same chain size
Old 03-18-2008 | 03:23 AM
tref357's Avatar
THX ONEWHEEL, I HEARD THE FRONT IS VERY HARD TP GET OFF. IN WANT TO GET MAYBE 500-1000 LESS IN HIWAY, IM NOT A STUNTMAN,DO 80% HIWAY DONOT GO FULL BORE ,IM A OLD MAN 52 MEXT MONTH! OTHERS LAUGH AT ME CUASE IM A OM, I JUST BLOW IT OFF I LOVE RIDEING THE ZZR600,.
TNX.TREF
Old 03-18-2008 | 08:21 AM
whitehendrix's Avatar
my rule to ratios:
1 down on the drive (front) sprocket = 3 up on the driven (rear) sprocket
this is the equivalent, and works in both directions..
driven performance is a great company tha i'll be a supplier of shortly wit any luck.. them, and a few others are quite reputable.. i've heard both good and bad about vortex.. not sure what to tell ya there...
and happy upcoming birfday!!!!
Old 03-18-2008 | 05:39 PM
Kohburn's Avatar
some sources like kneedraggers.com are helpful. you should be able to get a 520 chainconversion (one front sprocket, one rear sprocket and a new rollerchain)
shouldn't have any trouble getting +1 in the front and -3 rear.
Old 03-18-2008 | 09:36 PM
OMalley912's Avatar
New chain and spockets go togethter like pb and J! Right on tref...52 and still going strong! Teach them newbie punks on the road how to do it!
Old 03-19-2008 | 04:18 AM
zzrick's Avatar
Check here, I just ordered mine the other day, although I went the other way with my sprockets...http://www.pit-bull.com/
Old 03-19-2008 | 05:04 PM
tref357's Avatar
DEAR KF,I WANT TO MAKE TRILAL RUN BECAUSE OF THE CROSS COUNTRY STRAGHTWAYS OUT WEST THE ZZR IS A SPROT TOURER SOO....WANT TO SEEL HOW RELAX SHE IS IN HIWAY THATS ALL FOR YUR HELP,BEST TREF
VR4Mit3000GT
05-09-2009 12:37 AM
broncoffroad
12-20-2007 04:46 AM
frrogger1
08-28-2006 08:47 AM
gfoster
08-19-2006 10:44 AM
frrogger1
03-09-2006 08:30 PM
Quick Reply: i want to up the sprocket setup for hyway
