99 zr-7 carbs?
99 zr-7 carbs?
just picked up this bike. my question is this the carbs are dirty and so i cleaned them by taking them about and soaking them in carb solution for 10 minutes air dryed them and then put them together ,the bike started but as soon as the choke was turned off the bike quit would start again but only with choke ,all hoses are on ?i even tried the old starting fluid but now i don't even get it start at all, check spark ,good check gas coming out of valve,any ideas thanks motor
slow jets are still gummed up and or the adjustment is off. 10 minutes is not long at all even using pressurised air to dry the parts out.
I soak overnight normally then using a brush and air hose every part is cleaned.
Which bike are you referring too? A zr-7? I am not sure on that sensor just yet. What did you find in the fiche for your bike? That should help you out some until your manual shows up.
Wouldn't use too much starting fluid. It works fine for a "quick start," but if you know you have fuel delivery problems which make using fluid the only way to get running, FIX the problems before you create more by using fluid. It dissipates the oil in your cylinders, which is NOT what you want when pistons are doing their job.
+1^ Drag; still gunk in carbs.
did as you said cleaned carbs better and then took the tops off and found that the air hole was covered buy the legs of the spring holder.the one that looks like a table and the spring sets in it.the bike started ,one last quetion is this the air /fuel mixture screws are hidden should i take the cover off and adjust then or just leave them. ,the bike does have a muzzy pipe,and the needles are not stock,1&4 are on thread 3 and 2&3.are on thread 2 the adjustment screw covers are still on,bike runs just thought i may need to take care of this to run better,thanks .motor
heres' one more question these carbs have this sensor on the side of them ,i don;t know if this is an isuue or not. i do need a battery on this but went i jump the bike with a box or bike to bike ,the bike run;s until i take the cable off then you can see the lights and tach go dead and then the bike,is this due to this sensor.acting like fuel injection??
2000, adjust, adjustment, carb, carburetor, carburetors, choke, fluid, forum, holder, kawasaki, starting, zr, zr7, zx7r
