Steering Stabilizer
hmm, debate mode: BR at a buck 40 straight line. Colliding with an 1100 when the rider and you do a side to side collapsing of fairings, pushes you off with a tank slapper. You ride it out. So where would the damper be of benefit?
I tend to agree with Drag. I think the damper can mask some chassis problems (and rider problems, but that's a different fix) which don't become apparent until the damper won't save the situation and it's too late. Are they "cool?" Yeah. Great idea? Yeah. Do they work? Yeah. Do you NEED one? Mmmm, probably not, 98% of the time.
Most if not allracebike have steering dampers and almost all the newer 600cc plus sportbikes are starting to have them on stock. I know that my 03 636 needs one bad Got a hyperpro on her). On a racebike, if you get a tank slapper, you will lose time trying to ride it out or wait for things to calm down so it's used as a preventative tool. By the time you recover, you may be heading off the track, road or into an oncoming car. The new supersport bikes have so much more power (especially the 1000's) that during acceleration, the front wheel will come up and if it isn't straight when it touches the road, it will try and starighten itself leading to a tankslapper. This will be worse if still leaned over. You cannot react fast enough to correct the wobble and actually make it worse by fighting it. The damper does exactly what the name states; dampens the wobble/ tank slapper. Bottom line: They do Work and are necessary even on a bike with the suspension tuned perfectly. Even MotoGP bike have them and I'm sure their suspensions are setup a lot better that ours.
Maybe I should've said "do I need one...."
Speed, I won't dispute your argument; you're probably right. One more reason to keep my old 9; I can control it.
![Wink](https://www.kawasakiforums.com/forum/images/smilies/wink.gif)
hmm, maybe so. But I have not had a ride yet that a damper is of the first importance to need it. But speeds quote
makes the most sense. Losing some time I can see.
ORIGINAL: Dragone#19
![Big Grin](https://www.kawasakiforums.com/forum/images/smilies/biggrin.gif)
RaceGass
12-04-2008 06:06 AM
