DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
problem with ZX9R ninja
Old 05-16-2013 | 03:51 PM
iceman_rene's Avatar
Angry problem with ZX9R ninja
engine overhauld, new valves installed, grinded, adjusted, everything.
Carburators disassembled/assembled, cleaned, iddle speed adjusted, synchronisation adjusted, everything.
problem:
Engine starts/runs on choke, to warm up, when i push back te choke, the engine runs for a little while on normal iddle speed [1000-1300 rpm] and then suddenly refs up to 3500-4000 rpm -for a little while-, but drops back again to iddle speed.
After operation of throttle, the refs again raise, and drop very slowly after little while, but then again, engine reffs up again to 3500-4000 rpm.
WTF could be the problem ???
Old 08-14-2013 | 04:45 AM
Havok_96_2008's Avatar
sounds like the carbs arent sync right.. had that happen to zx7
Old 08-14-2013 | 04:54 AM
josh_3010's Avatar
Carbs out of sync or maybe drawing air at one or more of the intakes. Get it to idle and shoot some carb cleaner on the rubber intake boots. If the Rpms suddenly change, you have an air leak.
gc1982
Ninja ZX-9R
05-18-2014 03:17 AM
daren1093251
Ninja ZX-9R
02-12-2014 03:21 PM
visser
07-15-2013 08:33 AM
sysroot
10-25-2012 07:15 AM
jamjwu142
04-28-2008 04:14 AM
